Author Topic: Trunk Diff Mount Torque  (Read 1326 times)
Harry
  • USA, TN, Knoxville
« on: April 12, 2023, 15:28:36 »
The Haynes manual says that the bolt for the differential rubber mount in the trunk is 87 ft-lbs.   The BBB says the torque for the "hexagon screw at the top of the rubber mounting for support of rear axle" is 18 mkg - which equates instead to about 130 ft-lbs.  That's a lot of toprque and quite a bit of difference in torque values.  Thoughts?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Pinder
  • USA, NJ, Edison
Re: Trunk Diff Mount Torque
« Reply #1 on: April 13, 2023, 01:48:31 »
i did 87. 130 sounds way too high. Go with the lower spec until you are sure it should be 130.
« Last Edit: April 13, 2023, 02:04:27 by Pinder »
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
