Author Topic: Door panel mounting  (Read 2222 times)
EeVeeWee
Door panel mounting
« on: April 19, 2023, 14:43:04 »
Unfortunately when I bought my 1965 230 SL, the door panels were already removed from the doors.
Now I try to assemble the doors again, so also the door panel.
See my pictures for the items I have.
Of course I found this very useful description:
https://www.sl113.org/wiki/ChassisBody/Windows#Adjustment
However I can't find how to mount the door panel.
Does anybody have tips of pictures for that?
Thank you in advance.
Again something else.
Lori
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: Door panel mounting
« Reply #1 on: April 19, 2023, 20:41:42 »
I can't really tell what's going on with your door panel but there should be a metal strip at the top.
Lori
1968 280SL (US)
EeVeeWee
« Reply #2 on: April 20, 2023, 08:43:27 »
I have this metal strip, it's on the highest picture lying on the door panel top.
But how must it be connected to the door panel?
BobH
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
EeVeeWee
EeVeeWee
« Reply #5 on: April 23, 2023, 12:30:19 »
I still don't see how the upper aluminum molding is mounted op top of the door.
Is it put together with the top of the door panel inside the clamps?
Duncan200
  • 18-10-20 Just started my Restoration
« Reply #6 on: April 23, 2023, 13:42:32 »
I’ve had my door trims recovered and I have not fit them yet.
I’ll take some photos for you, showing how it it held on by clips tomorrow.
Doug.
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
EeVeeWee
« Reply #7 on: April 23, 2023, 15:06:54 »
Doug.
Thank you in advance!
Lori
  • 1968 280SL (US)
« Reply #8 on: April 23, 2023, 15:24:43 »
There appears to be too much padding and the material shouldn't wrap all the way over that metal piece.  The chrome trim clips to the metal piece and then it fits into the clips on the door.
Lori
1968 280SL (US)
EeVeeWee
« Reply #9 on: April 23, 2023, 17:40:47 »
OK thank you. So it seems I have to remove a part of the padding and then put the smal part of the door trims on top of the end of the padding.
Thanks a lot!  :)
Duncan200
« Reply #10 on: April 23, 2023, 23:09:21 »
Looks like Lori beat me to it.
But yes, there are clips that hold it on the top edge and your trim appears to have too much material on it.
Doug.
getsmart
  • Australia, Victoria, Dromana
« Reply #11 on: April 25, 2023, 00:28:37 »
Hey evw  :)
By the thickness of it - it looks like the foam might have continued over the top metal strip, my old one appears to be just one layer of vinyl going over the metal strip...
Rgds, Joe
Finding the red car
1964 230sl Restoration Project
EeVeeWee
« Reply #12 on: April 25, 2023, 08:00:39 »
You're right, I've some rework to do.
EeVeeWee
« Reply #13 on: April 28, 2023, 14:24:26 »
Hey evw  :)
Rgds, Joe
This was exactly the case. Now it's changed and it fits like a glove.  :P
Thank you very much!
