Author Topic: Heater core refurbishing question.....!  (Read 1503 times)
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« on: April 25, 2023, 19:54:36 »
I have fitted the "new" heatercore in the car... ;) but wonder if i must glue some foam on the metal plate where "BEHR" is stamped ( i know the up side is in the wrong location.... i didn't told the welder  how.....)
I think i have seen somewhere that foam  , may be to avoid some rattling noises ?
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
Re: Heater core refurbishing question.....!
« Reply #1 on: April 26, 2023, 13:33:29 »
yves,
Sorry to side track your thread on the first reply!   ;D  Why did you mask off those parts and paint in this area?  Just curious, as I will be doing this work for sure some day.
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #2 on: April 26, 2023, 16:57:59 »
There's a pic in the tech manual that shows foam on the deflector plate
https://www.sl113.org/wiki/Electrical/HeaterCore
Lori
1968 280SL (US)
WRe
« Reply #3 on: April 26, 2023, 17:15:30 »
In my opinion, in order to still achieve good heating performance, it is important that the entire system works optimally, i.e.:
- a clean heat exchanger, inside and out
- a well-insulated heat exchanger so that it does not transfer its heat to the body panel.
.. WRe
yves
« Reply #4 on: April 26, 2023, 18:41:27 »
Thank's all for your contribution...!
So i'll put some glued foam on this side, that makes sense.
For Rwmestel, i had some superficial rust around the heatercore and the paint is a rust proof one  after a solid brush. I replaced also the two water drain hoses which were not so bad but i hope not going there another time....! :-\
« Reply #5 on: April 26, 2023, 20:18:16 »
For Rwmastel, i had some superficial rust around the heater core and the paint is a rust proof one after a solid brush.
Got it - keep up the good work!
