Not sure if this is an electrical problem or a fuel problem, but any thoughts and recommendations are welcome:
My 1965 230SL would not start this winter until I had cranked it multiple (10-20) times. It would catch slightly, then die. When it finally would catch, i needed to do some delicate footwork on the pedal to sustain the engine. Vehicle would run just fine once it started. It is garaged in an unheated space.
As the weather warmed in March I noted that it took only 5-10 cranks to get it going. I took it to my mechanic, who diagnosed it as the "time switch" was no longer working. I believe ja17 wrote about this in the Forum on Jan 10, 2016. The mechanic noted that during the warmer weather the engine should start fine without this switch.
The engine fired up on the first try when I took it out recently. Looked like a good sign. After parking for an hour, it took me about 30 or more cranks to get it started. Just when the battery was starting to show signs of fatigue, the engine caught and I could get back to my garage.
Back in the garage, I parked and turned it off. Tried to start it again, but still needed a couple of cranks.
Do I need to replace that time switch or is something else going on that needs looking into? Many thanks in advance for any advice.
