Author Topic: Cleaning MB-Tex tips  (Read 3011 times)
sl113newguy
  • USA, CA, Palo Alto
  • ...just getting started
« on: May 09, 2023, 16:12:52 »
A simple one...
For cleaning MB-Tex, is all that is required is any vinyl cleaner?
Not just for seats, but for doors (have a bit of staining...not sure what from, perhaps water over the years), rearview mirror, etc. I've seen a bit here on caring for leather, but haven't found (apologies if looking past) if anything special required for MB-Tex on cleaning and care over the years.
Thanks forum
1968 280SL Automatic (USA) 350 Medium Blue
Jordan
  • Canada, ON, Jordan
Re: Cleaning MB-Tex tips
« Reply #1 on: May 09, 2023, 16:38:26 »
I find Mr Clean magic eraser works really well on vinyl.
Marcus
66 230SL  Euro 4 speed
lreppond
  • USA, CA, San Leandro
« Reply #2 on: May 11, 2023, 17:58:39 »
I’ve used 303 vinyl cleaner and then followed up with their protectant with excellent results on MB Tex. It leaves it very clean (especially if you use a detailing brush) and somewhat more pliable.  The protectant leaves it with a matte finish.  It’s smells clean too.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
sl113newguy
« Reply #3 on: May 11, 2023, 22:12:36 »
Thanks @Jordan
@lreppond - do you use the '303 clear vinyl protective cleaner' or the '303 multi-surface cleaner'?
Curious if one is preferred just for MB-Tex v other surfaces.  Thanks again.
lreppond
« Reply #4 on: May 13, 2023, 18:48:59 »
I use the “303 multi surface cleaner” and then follow up with their protectant.  I’ve used this regiment not only on MBTex but guitar cases, typewriter cases, etc with absolutely excellent results.  It also worked quite well on the sun visors on my w113 which have a textured surface that collects grime.  I could be wrong but I think the protectant has a UV blocker.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
sl113newguy
« Reply #5 on: May 13, 2023, 20:40:55 »
Thanks Len
