Author Topic: "common problem of the AC compressor pulley hitting the sway bar..."  (Read 1716 times)
teahead
  • USA, WA, Des Moines
  • aka "Rob"
I just talked to my frame shop who were installing new front springs.
I had them also install a 22mm sway bar to replace the 20mm that's in there.
They told me that there's "no way" that sway bar will fit because it's hitting the compressor.
I did a search and other than this thread about the Fantomworks 230SL resto:
https://www.sl113.org/forums/index.php?topic=22803.0
I can't find anything about this "common problem."
I wonder if I have a 280SE sway bar, or is that extra 2mm (280SL stock is supposedly 20mm) really interfering that much into the ac compressor?
I haven't gotten it home yet and removed the sway bar to compare the bends are the same or not between the two bars.
« Last Edit: May 09, 2023, 21:51:31 by teahead »
teahead
  • aka "Rob"
I'm wondering if something like these would work (gotta check the hole spacing of course):
The shop can't lay them beside each other and compare?  Send you a pick of them side by side?
teahead
  • aka "Rob"
by the time they told me, they put the old bar back on.
teahead
  • aka "Rob"
Well...I tried adding 1/4" shims.
Still no go, so I'm going to put up the 22mm sway bar for those WITHOUT AC!
