Author Topic: Time Switch Relay  (Read 4136 times)
Brandini
  • USA, WA, Seattle
Time Switch Relay
« on: May 10, 2023, 21:29:28 »
I have a 1964 230SL and believe I need a new time switch relay (round) as noted in this picture.
Does anyone know where I could purchase one or is there an alternative option?
Brandon
1964 Mercedes 230SL
Seattle, WA
lpeterssen
  • USA, FL, Miami
Re: Time Switch Relay
« Reply #1 on: May 10, 2023, 21:45:58 »
Dear Brandon
Let me think in a solution for you.  Normally on all the wiring harnesses that pass through my hands for refurbishing, I do modify the logic of the wiring loom so that it resembles the one used on later 250/280SL.
That is an option, to service the harness.
The other possibility is to build a subharness to plug into your actual timed relay socket and then use a regular HELLA, ISO compliant timed relay instead.
Let me know what would you prefer to do.
After 50. Years if your harness is original, is impossible that it will not have its weak points.   Cinderella needs always your attention.
Best regards
Eng. Leonardo Peterssen
lpeterssen
  • USA, FL, Miami
Solution found , harness built and product sent Time Switch Relay
« Reply #2 on: May 12, 2023, 22:48:28 »
Dear friends
For whoever is on this same situation with a non working 1sec timed relay, here I found for Mr. brandini a solution built on HELLA timed relays.
The relay should be bought and sent to me at any circumstance since there are different models, and not all, even looking exactly the same do the same thing.
There are DELAYED ON relays, DELAYED OFF, etc.
Look at the picture with the solution.  Harness for 120$ plus shipping.  The relay cost about 65$ plus freight and taxes.
Best regards
L.Peterssen
m300cab
  • USA, Pennington New Jersey
« Reply #3 on: May 15, 2023, 20:46:55 »
if you are still looking, let me know.
I may have a used one in my pile of relays.
Michael Parlato
benzwallah
  • USA, VA, ALEXANDRIA
« Reply #4 on: September 28, 2023, 00:34:02 »
To m300cab: I am still looking for a time switch relay for my 1965 230SL  If you have one available, I would be very interested.  Many thanks - benzwallah
benzwallah
1965 230 SL
silver w/navy blue soft top, grey hard top
lpeterssen
  • USA, FL, Miami
« Reply #5 on: September 28, 2023, 10:48:11 »
For all you I found this on eBay.
https://www.ebay.com/itm/115889290359?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=xH7l50NHTBm&sssrc=4429486&ssuid=xQJlZWrBRO-&var=&widget_ver=artemis&media=COPY
That is a brand new timed relay original
But for a super high price 400$
Best regards
L.Peterssen
m300cab
« Reply #6 on: October 01, 2023, 16:41:30 »
I have a good used one
Michael Parlato
