Author Topic: Door handles  (Read 2489 times)
Brennie
Door handles
« on: May 11, 2023, 10:44:32 »
Hi …question..are all door handles the same? Can left and right be swapped if cylinder is turned correctly? And,crucially,are they all the same size? I have an SL230 and attempting to change the handle but,the new handle is not quite fitting..it seems a fraction out length wise..
Re: Door handles
« Reply #1 on: May 11, 2023, 13:29:15 »
Another question is, were the handles the same through the production run?  I know key types changed, but I don't know if the actual door handles changed.  You might be trying to put a 280SL handle on your 230SL (not a SL230).  Also, if you've got new rubber pads/seals between the door and the handle, that might make it a tighter fit than before.
Re: Door handles
« Reply #2 on: May 11, 2023, 13:32:08 »
https://www.sl113.org/forums/index.php?topic=30203.msg218868#msg218868
A quick Search brought up many threads, and in the first few was this message.  Left and right are the same.  Search is great!!
