Author Topic: my 69 280Sl Automatic  (Read 1308 times)
travellerdogs
  • Canada, British Columbia, Bowser
« on: May 13, 2023, 23:43:19 »
I have a low idle situation and the engine is running too rich. I've done the Linkage tour many times. The constant Speed solenoid has power but the solenoid rod that should hold the linkage is not holding. There is 12 volts going into the wire terminals. i am assuming this is meant to dampen the linkage when it's idling. This is not a USA spec's system. It does not have the damper at the Venturi connection. I'm in the BBB reading, I seem to have forgotten a lot lately as I've had this car for quite a few years. A bit of advice would be appreciated. Thanks.
travellerdogs 1969 280SL,  1981 380SL:  1955 HD Panhead: 2007 HD Street Glide: 1956 Mercury Montclair, Black 2 Dr Htp; 1965 230SL: 2005 Pontiac Sunfire: 1993 Range Rover: 1977 450SL parts car:
