Author Topic: Steering Play  (Read 1662 times)
Harry
  • USA, TN, Knoxville
Steering Play
« on: May 14, 2023, 15:19:28 »
So since I had removed, refurbished and reinstalled the front end on my 1966 230SL, I have been plagued a bit by play in the steering.  I just replaced the nylon bushings that join the steering column and the steering box so that is not the issue.  I'm about to adjust the power steering box itself but I thought before doing so, I'd run the issue by this team of owners/mechanics.
Thoughts?
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: Steering Play
« Reply #1 on: May 14, 2023, 18:44:19 »
most recirculating ball steering boxes has an adjustment screw on the top.
Haven't looked at my car to know for sure.
Tighten to see if it helps.
dirkbalter
  • USA, CA, Corona
Re: Steering Play
« Reply #2 on: May 14, 2023, 19:11:47 »
I would be careful to "willi nilli" tightening screws on the steering box. There is a bit more to it. The rebuilding and setting up of the steering box is described in the BBB (full version) extensively.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Flim
  • United Kingdom, England, Flimwell, East Sussex
Re: Steering Play
« Reply #3 on: May 18, 2023, 13:01:34 »
Have you checked the steering damper?
Re: Steering Play
« Reply #4 on: May 20, 2023, 15:40:22 »
Thoughts?
Harry
Harry--do you know if the play is in the steering box, or elsewhere? I think the steering column has a universal joint on it for earlier cars and sometimes this can wear out and exhibit play. May be something to check.
If there's play in the box itself, C&M Hydraulics is the acknowledged leader in rebuilding. You can find their rebuilt boxes in a number of places, bought on exchange with a suitable core...
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
Re: Steering Play
« Reply #5 on: May 22, 2023, 00:53:16 »
I replaced mine with a rebuild by C&M Hydraulics.  I am so happy with that decision. In my opinion, you can adjust and adjust a little more and never have the steering performance you want.
Good luck with your project.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
