Author Topic: Drain holes location picture  (Read 2703 times)
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« on: May 22, 2023, 00:59:50 »
I think I remember seeing a picture that showed all the drains under the car but I can’t find it now when I need it. Typical. I have the information from the technical section but I can see there are more locations. I have the axel, fuel tank, etc out of the car. This is a great time to find and repair all the drains.
Thoughts?
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
Re: Drain holes location picture
« Reply #1 on: May 22, 2023, 12:32:49 »
https://www.sl113.org/wiki/ChassisBody/Drains
If you're looking for more than this, then a patient look through search results should give you want you're looking for.  Are you only concerned about the rear of the car?  You mention axle and fuel tank removed.
