Please check out joining the
Emergency Contact List
for help during your travels!
230 sl piston
Topic: 230 sl piston (Read 2510 times)
Dejan mb
Inactive
Junior Level
Slovenia, Ljubljana, Ljubljana
230 sl piston
May 22, 2023, 16:00:17 »
Hello I have a problem geting new pistons for 230 sl. it has to be 3 generation of pistons whit 25mm pin and size 83mm.
does anybody know where to buy?
thanks in advance
Harry
Full Member
Gold
USA, TN, Knoxville
Re: 230 sl piston
June 08, 2023, 01:46:16 »
I rebuilt the engine on my 230SL a couple of years ago and bought the pistons from the Classic Center. 1st and 2nd oversize were available but the 1st OS were more expensive.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Associate Member
Platinum
Canada, ON, Port Lambton
Re: 230 sl piston
Reply #2 on:
June 08, 2023, 03:20:23 »
3rd generation 230SL pistons are often stepped and low compression - max 150 PSI.
If you get early pistons you will need connecting rods to match the pistons but it's what I would do.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
1988 560SEC
Esmo
Full Member
Junior Level
United Kingdom, Wales, Conwy
SL 230 1967
Re: 230 sl piston
Reply #3 on:
June 08, 2023, 18:28:13 »
The MB number for Gen 3 83mm is 180 030 71 18 always easier to find using the number . Good Luck
230 sl piston
