Author Topic: Door Lock help  (Read 2040 times)
69280sl
  • USA, IL, Elk Grove
Door Lock help
« on: May 28, 2023, 00:50:04 »
My doors (1968 280sl) have never been lockable from the outside with the key. With the locks removed from the car the key swings to the left and right as it should. With the locks in places the key does not rotate but does press in to release the door. The "fork" on the lock is clearly not "mating with whatever on the part set into the door edge.
Seems like only one way to fit the lock in. Is there any secret?
All suggestions are appreciated.
Gus
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: Door Lock help
« Reply #1 on: June 06, 2023, 23:03:24 »
Lori
1968 280SL (US)
Leester
  • USA, VA, Lorton
Re: Door Lock help
« Reply #2 on: June 07, 2023, 13:27:00 »
Here's another:  https://www.sl113.org/forums/index.php?topic=31045.msg225461#msg225461
Hopefully your door handle locking mechanism is not broken (as shown in the photo).
When I refitted door handles after painting I found that you have to get the notch of the door handle lock (number 2 in the picture) matched up just right to the locking mechanism on the door.  As the handle is presented to the door, I had to get the angle just right for the two mechanisms to match up. You can take the door handle off without taking the door card off but to put it back in and match the lock mechanism on the door, you may have to remove the door card.
Lee Backus
1963 220SE Cabriolet
1985 500SEC
69280sl
Re: Door Lock help
« Reply #3 on: June 15, 2023, 22:46:23 »
Thank you Leester. I will try again.
Gus
Leester
  • USA, VA, Lorton
Re: Door Lock help
« Reply #4 on: June 22, 2023, 18:32:41 »
I see only one photo ended up in the reply.  Hopefully both are shown now.
Lee Backus
1985 500SEC
69280sl
Re: Door Lock help
« Reply #5 on: June 22, 2023, 23:36:31 »
This looks promising. I will try it.
Very much appreciate your help.
Gus
