Author Topic: 280 SE/NV engine  (Read 3614 times)
hjhofman
280 SE/NV engine
« on: May 27, 2003, 05:56:45 »
All,
I found out that the engine of my 1964 230 sl is replaced with an 280 SE/NV engine from probably a W 109 or 111
can anyone tell me what the NV stands for
regards,
herbert hofman
HERBERT HOFMAN
Klaus
Re: 280 SE/NV engine
« Reply #1 on: May 27, 2003, 09:08:25 »
Herbert,
NV probably means "Niederverdichtung", low compression ratio. Engines with lower compression ratio were available for countries with lower octane gasoline, to prevent knocking.
Engines with NV had a different "Baumuster", i.e. engine number. E.g. a 280SE engine number with regular compression ratio might start with 130.980...., while the low compression version would start with 130.984....
Klaus
