Author Topic: Passaenger-side Front Inner Wheel House Thin Panel that Connects House to Fender  (Read 3663 times)
Cole
  • USA, CA, Los Angeles
On the outer side of both front, inner wheel houses, there's a thin connecting panel that is bolted onto the edge of the housing and fender.
Please see attached pictures with the missing panel enlcosed in a orange.
If you have access to a pagoda it will probably be more clear.
I need this panel on the passanger side.
Thanks!
Cole
Cole
'69 280SL, 40G Black/Burgundy Interior
A113 840135 or A1138840235
Available from your Mercedes dealer and not very expensive.
If you are calling dealer about it, there are a couple of weatherstrips that are coming with it, one per side, A 000 987 16 51 RUBBER SEAL replaced with A 110 884 00 98 SEAL 770 MM AT PARTITION PANELS
There is also discussion on the Forum about the type of screws used for it. Cannot find now, but as I recall - hexhead tapping screws 5.5mm with washers, 6 per side.
« Last Edit: June 06, 2023, 15:54:07 by Pawel66 »
Cole
Thanks a lot, guys!
Much appreciated!
Cole
Cole
