Author Topic: 230 Trunk lid will not open  (Read 1654 times)
Kenscar
  • USA, VA, Flint Hill
« on: June 11, 2023, 17:17:37 »
I have a '66 230, the trunk will not open.  Is there a way to open the lid? The barrel pushes in but it will not release.  It has been working along.
mnahon
  • Canada, QC, Montreal
Re: 230 Trunk lid will not open
« Reply #1 on: June 11, 2023, 20:06:51 »
This is probably a stupid question, but are you sure it's not locked?
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #2 on: June 11, 2023, 22:00:38 »
If it is locked and you are unable get into your trunk it could be that the push pin has fallen off of your lock. I have a way to get into locked trunks so PM if you need help.
Kenscar
« Reply #3 on: June 12, 2023, 22:26:18 »
The trunk is not locked.
mnahon
« Reply #4 on: June 13, 2023, 20:59:39 »
You should PM Dan (BenzDr); he may have a way for you to open it.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
« Reply #5 on: June 14, 2023, 13:41:16 »
Just a couple of thoughts:
There is license plate illumination on the underside of the license plate "cove" adjacent to the trunk latch button.  After removing the clear plastic lens and the bulb (and disconnecting the battery!), is there any access to trip the mechanism from that point?
Inside the soft top compartment there is a 2–3-inch round hole at the center of the rear wall that may give a little access to the trunk area.  It there a way to trip the mechanism from there with a length of rod?
