Author Topic: 230SL Hot start fiddle.??  (Read 1569 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: June 14, 2023, 14:46:28 »
My 230 starts perfectly cold, and in the winter starts hot not too badly, but now we have some VERY hot weather (rare in the UK I know!) the other day with the car in the sunshine it started for a second, then just cranked and cranked. (perfect spark).   Seems the fuel injection system runs out of fuel and wont "prime".   Suggestion is to "fiddle" the cold start unit so it will inject a fuel shot (or 2) even when hot to help it "prime"once the cold start squirt of fuel starts the engine.
So, anyone know how to do this with the cold start unit?
Alternative is that the non return valves in the injection unit need to be replaced, but the parts are like hens teeth but not as easy to find ??? Anyone know the part numbers?
Any suggestions very welcome!
Many thanks.
Re: 230SL Hot start fiddle.??
« Reply #1 on: June 15, 2023, 01:47:04 »
Cold or hot, I find that turning the ignition on and letting the fuel pump pressurize the lines for about 15-20 seconds, then turning it off and turning it back on again and cranking works pretty well.
ctaylor738
  • USA, VA, Falls Church
« Reply #2 on: June 15, 2023, 03:26:57 »
On some cars, flooring the gas pedal while cranking will get the engine going.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Paul & Dolly
  • i Car
« Reply #3 on: June 15, 2023, 07:15:48 »
I let the fuel pump prime for ablout 10 secs before cranking .
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
jackmc
  • USA, AZ, Tucson, Arizona
« Reply #4 on: June 23, 2023, 03:37:55 »
Perhaps related to my issue.
Just started a “Fuel issue on hot start” thread. Hopefully between the two we can both get going again.  8)
