Author Topic: Temperamental 230SL After New IP Installed  (Read 7928 times)
Re: Temperamental 230SL After New IP Installed
« Reply #25 on: July 19, 2023, 14:09:43 »
Some good work being done here but you really need an exhaust gas analyser with HC displayed as well as Co.
High HCs are always a good indicator of a problem.
ctaylor738
  • USA, VA, Falls Church
« Reply #26 on: August 20, 2023, 21:34:21 »
You said that you replaced the injectors.  Were the replacements new? If not, did you test them. I have a theory that injectors that pee rather than spray have a disproportionate effect on the low-rpm mixture.
I also suggest changing the oil in the pump.
You can also try going a couple of clicks lean on the rack.
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
