Author Topic: Windshield Install - screwheads  (Read 1409 times)
Leester
  • USA, VA, Lorton
« on: June 19, 2023, 18:26:39 »
I am working my way to a windshield install and plan to have someone come and do that. However, in preparation for that event I have encountered an issue with several screwheads protruding from the chrome side and top pieces. I first tried using a drill bit to try to countersink the screws but that hasn't really worked. I ended up using some mortite rope caulk as seen in the photos to try to build up a little around the screwheads. I am trying to avoid having the screwheads "show" under the windshield seal after it is installed.  Am I overthinking this?
The screws are 2,9 x 9 which should be the correct size.
Lee Backus
1963 220SE Cabriolet
1985 500SEC
