Author Topic: Frozen Thermostat bolt  (Read 1998 times)
George Lollar
  • USA, VA, Fairfax Station
« on: June 20, 2023, 18:12:52 »
I need to remove thermostat cover and bolt over head is frozen.  Tried penetrants and shock, heat is next, but that has complications.  To heat I need to remove injection lines and heat may impact head gasket.  Does anyone have any suggestions or magic?
George Lollar
George Lollar
1970 280SL Green/White
1994 E320 Coupe
BobH
Re: Frozen Thermostat bolt
« Reply #1 on: June 20, 2023, 18:39:54 »
Hello George, if you search for "thermostat replacement", there are lots of posts, seems like it can be a pain to remove the cover, i found this one with some good tips
https://www.sl113.org/forums/index.php?topic=30683.msg223178#msg223178
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
George Lollar
« Reply #2 on: June 21, 2023, 21:15:25 »
Bob -  Thanks for the suggestion. George
George Lollar
1994 E320 Coupe
