Author Topic: Ever curious what no fuel to fuel pump looks like  (Read 3483 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« on: June 20, 2023, 18:49:02 »
No fuel to cool pump and you keep it running.  :(
Bob "Baron" Youngman
1965 220se coupe restomod
BobH
Re: Ever curious what no fuel to fuel pump looks like
« Reply #1 on: June 20, 2023, 19:14:50 »
Hello Bob, how long do you think it would take to overheat and burn out?  Seems if owners have trouble starting their car, the pump could be running for some time while they try and diagnose the problem, seems it should probably be the first thing to check
Second and possibly a dim question, but what's different with the early pumps that weren't cooled, how are they designed to run without cooling?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Kevkeller
  • USA, HI, Honolulu
« Reply #2 on: August 21, 2023, 13:37:14 »
I had one melt all the plastic.
1970 280 SL
« Reply #3 on: August 22, 2023, 17:50:13 »
For the uneducated and inexperienced in the classroom, maybe you can show side by side this one and a normal used one.
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #4 on: September 13, 2023, 16:32:01 »
Didn't have a used one but here is a burnt and melted one vs rewound one. In second picture you can see where glue was melting and coming out...ouch
Will be giving a fuel pump rebuild demo st pagodafest chicago
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« Reply #5 on: September 20, 2023, 16:23:39 »
I will be at the demo. Should I bring my pump? ;).
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« Reply #6 on: September 22, 2023, 23:20:10 »
Sorry. I already have one I am rebuilding at Pagodafest. If you want to bring it, I  can rebuild and mail back to you. I usually test pumps for a total of 6 hours. That is so brushes can start to make groove and seat in armature.
