Author Topic: Clock adjustment and bulb replacement issues  (Read 3438 times)
Brennie
« on: June 27, 2023, 13:19:17 »
Hi
I have my clock out and I’m trying to adjust the time( it runs slow) I know how to do the..
it’s just that is doesn’t run when I attach it to a small 12volt battery.. I see the earth (ground) and two positives..+1 and +0 .. I’ve tried both and the clock still isn’t working??
What am I missing..?
« Last Edit: July 10, 2023, 17:10:20 by Brennie »
Re: Clock adjustment
« Reply #1 on: June 28, 2023, 11:25:21 »
There's a thermal fuse in there, that may be shot.
https://www.sl113.org/wiki/Electrical/Clock
Brennie
« Reply #2 on: June 28, 2023, 11:43:15 »
It’s working now… just need to patiently adjust the timing…
Thank you for your reply..
Brennie
« Reply #3 on: July 10, 2023, 17:09:24 »
Another thing .. thought about replacing the bulb while in there..
thought about an LED.. ordered it from a classic LED supplier.. was told the supply lots of Pagoda enthusiasts with all the required bulb swaps..
Mine arrived but, doesn’t fit.. nor does the modern replacement ordinary bulb??
The brass one is the original.. and fits perfectly..
dirkbalter
  • USA, CA, Corona
« Reply #4 on: July 10, 2023, 17:18:35 »
I had a similar problem with the ordinary replacement bulbs. In my case, the solder dot would interfere. I had to "gently" grind it down a bit to work.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Brennie
Re: Clock adjustment and bulb replacement issues
« Reply #5 on: July 10, 2023, 17:34:39 »
Hi Dirk..
In this case.. the newer ones just seem too wide(fat) to even fit in the hole…
Brennie
« Reply #6 on: July 10, 2023, 17:37:02 »
LED offered up.. just won’t fit.. neither does the standard replacement..
« Reply #7 on: July 10, 2023, 19:12:33 »
More importantly, who lives in the crate?  Lots of dog lovers here!   ;D
Brennie
« Reply #8 on: July 10, 2023, 19:17:14 »
Him..
Paul & Dolly
  • i Car
« Reply #9 on: July 11, 2023, 07:31:59 »
Re Clock Bulb
I had the same problem when I changed my dash lights to LEDs, all ok except for the clock.
I found that Halfords did an LED  ((Glass bulb type) that fitted, They were in a twin pack in bubble wrap.
Unfortunately one of them shot out of my hand across the garage floor, never to be seen again ! Good job there were 2.
Hope this helps    https://photos.app.goo.gl/dw6X6Ceydwvk54GU2
A link to my googlephotos, the clock is there, dont loose the little spring ring.
Paul
« Last Edit: July 11, 2023, 07:40:05 by Paul & Dolly »
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
Brennie
« Reply #10 on: July 11, 2023, 07:36:49 »
Thank you Paul
I’ll check those out.. I don’t suppose the know  exact bulbs do you?
And.. did you change them all successfully? Do they dim? I also believe there I one you don’t change .. it cause too much resistance or something like that..
Brennie
« Reply #11 on: July 11, 2023, 07:43:04 »
Any of these?
Brennie
« Reply #12 on: July 11, 2023, 07:47:50 »
These?
Paul & Dolly
  • i Car
« Reply #13 on: July 11, 2023, 07:55:14 »
Hi Brennie
It is a T4W,  & I think that is the correct pack you show, and it does dim.
I did not change any in the central instrument cluster, (The Charging lamp should NOT be changed for LED).
You can see I did the Heater slides twice,(first time not bright enough)
The tacho, Speedo, and headlights except the fog lights & Indicators.
No real problems, but the side lamps needed to be fitted from inside the headlights ,as they would not go through the hole from outside.
Others have done the Indicators, but that again can present problems with resistance.
Good luck
Paul
Mitsubishi i Car
