Author Topic: ID PLATE  (Read 1691 times)
FILIPPO458
  • Italy, Emilia-Romagna, bologna
ID PLATE
« on: July 13, 2023, 11:32:16 »
Hi everyone I've a 230 sl pagoda from 1965 ,frstly ordered in europea  ,where are supposed to be the id plates?
Re: ID PLATE
« Reply #1 on: July 13, 2023, 12:58:42 »
My first suggestion would be to use the Search feature.  As a Full Member, you also have access to the Technical Manual.  https://www.sl113.org/wiki/DataCard/BodyandPaintNumberPlate
FILIPPO458
Re: ID PLATE
« Reply #2 on: July 13, 2023, 13:56:05 »
Thank you I will !
Re: ID PLATE
« Reply #3 on: July 13, 2023, 14:25:26 »
My 230SL was originally sold in Bergamo, up near Milan.  It still has the dealership sticker in the hard top window.
Good luck with your ID plates.  If yours are missing or in poor condition, they can be remanufactured.
MikeSimon
  • USA, OH, North Royalton
Re: ID PLATE
« Reply #4 on: July 13, 2023, 14:32:05 »
The pictures in your original post show two different plates. The upper one is the "data plate" containing key option information, which is/was mounted on the inner fender rail for, I think, all models. The lower one is the "VIN plate", containing the chassis-no and other info. This plate was/is mounted on the firewall in a padding cutout in front of the passenger position. This location is correct for all Euro cars and early 230SLs in the U.S. for later U.S. models, this plate was moved to the driver side door area.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
FILIPPO458
Re: ID PLATE
« Reply #5 on: July 16, 2023, 22:48:19 »
Ah ok thank you so much I found both of them !!
