Author Topic: Shifting Rod  (Read 1672 times)
cajlouni
  • USA, CA, San Jose
Shifting Rod
« on: July 15, 2023, 05:07:18 »
Hi
My shifter for my 71 280 SL has become extremely loose and at times very difficult to put in gear. I was told that the rubber washers underneath needed to be replaced. Can anyone appointment in the right direction or give me the proper name on what I need to order?
BobH
Re: Shifting Rod
« Reply #1 on: July 15, 2023, 07:45:35 »
Hello, if you search "shifter bushes", or "shifter linkage", using the general search above left, you'll find lots of advice, including this post:
https://www.sl113.org/forums/index.php?topic=10787.msg71617
Also a description on here in the technical manual:
https://www.sl113.org/wiki/TransmissionClutch/Shifter#ManualShifter
« Last Edit: July 15, 2023, 07:49:42 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Re: Shifting Rod
« Reply #2 on: July 15, 2023, 13:46:22 »
It's best to replace all the plastic bushings while your at it, since they all degrade with time and use.
