I OWN A REPAIR SHOP BUT HAVE NEVER WORKED ON A PAGODA BEFORE SO ITS BEEN A LEARNED CURVE TO SAY THE LEAST.
cahoon485,
Hi. Welcome to the forum! Just so we have a baseline on your experience, how familiar are you with the Bosch/Mercedes mechanical fuel injection system? You must be somewhat experienced with it based on your above posts. If you want additional details....
There is a Linkage Tour thread:
https://www.sl113.org/forums/index.php?topic=5003.0Better yet, in our technical manual, there is this:
https://www.sl113.org/wiki/Restricted/Linkage-tourThanks for the photos. Now that we all know you are talking about the main rack enrichment screw on the back of the pump, and the intake venture stop screw on the intake manifold, everyone can give proper advice.
My advice is to set a known good baseline from which to troubleshoot. There are SOOOO many things that can be worn, broken, out of adjustment. Everyone can jump in here on what all can be set back to factory spec, but my list starts with:
- Using above links, ensure all the linkage is set to factory spec lengths.
- Ensure the intake venturi stop screw is set right.
- Ensure the ignition timing is right. (Your rebuilt brake booster helps with the vacuum affect on the distributor.)
- More, anyone?
Then perform the split linkage test and report back with results.
(Maybe you can stop typing in ALL CAPS?)
