with our official
Pagoda SL Group logo
from our official partner.
installing Mercedes 280sl Cotter Pin for Rear Diff Mounting Strut
Topic: installing Mercedes 280sl Cotter Pin for Rear Diff Mounting Strut (Read 1394 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
July 28, 2023, 18:27:25 »
Having one heck of a time trying to install the pin for the rear axle center joint pin. Do I really need this pin?
1950 MG-TD
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: installing Mercedes 280sl Cotter Pin for Rear Diff Mounting Strut
July 28, 2023, 18:47:42 »
I think you already know the answer.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #2 on:
July 28, 2023, 18:54:01 »
Make sure it is going in correct.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #3 on:
July 28, 2023, 19:11:01 »
Have it going the right way. On the end of the center joint pin there is a slot so you can adjust it so the flat spot is aligned properly, is there a clock position of that slot that would get me in the approximate position?
1950 MG-TD
dirkbalter
Full Member
Platinum
USA, CA, Corona
Reply #4 on:
July 28, 2023, 19:49:25 »
I don't recall that I had issues with the pin, so I don't exactly remember. I would think you can stick a small screwdriver or similar in there and kind off feel the flat coming around?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #5 on:
July 28, 2023, 20:16:28 »
Hopefully this will help someone else. On the back of the pin is slot across the pin, set it to the 3 & 9 O'clock position and install the pin using minor adjustment if needed this will place the flat spot so you can install the cotter pin.
Last Edit: July 28, 2023, 20:57:14 by CJHenderson
1950 MG-TD
