Author Topic: Labelling of the TTS in Our Manual  (Read 2084 times)
Harry
  • USA, TN, Knoxville
« on: July 30, 2023, 15:07:44 »
Quick question.  In the Engine Starting Aid Tour photo of the TTS, Terminal G is identified as the one on the "sloped" side of the insulator and Terminal "W" is indicated as the one on the straight side of the insulator.  This is opposite to how the TTS in my 1966 230SL is labeled.  My TTS labelling appears to be correct because the "W" terminal shows zero resistance to ground whereas the "G" terminal shows a small resistance to ground.
Just want to be sure that we are clear and correct on the labelling in the illustration.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
BobH
Re: Labelling of the TTS in Our Manual
« Reply #1 on: July 30, 2023, 15:35:17 »
Hello, i think it may be either an optical illusion, or a mirror image.  Terminal W looks to be on the taller post
If you look at these pictures, the top left picture shows the taller post on the sloping side of the insulator, whereas the picture below shows the opposite
https://www.sl113.org/wiki/Engine/ThermoTimeSwitch
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #2 on: July 30, 2023, 16:23:13 »
... Terminal G is identified as the one on the "sloped" side of the insulator and Terminal "W" is indicated as the one on the straight side of the insulator.
I think he's indicating the labeling of the picture is incorrect?
BobH
« Reply #3 on: July 30, 2023, 16:55:59 »
I don't believe the labeling is incorrect, the larger terminal and eyelet on the taller post is connected to W. The two pictures show the larger post on different sides to the sloping side of the insulator, so perhaps the insulator could have been assembled in two different ways, or the pictures are deceiving?
I haven't seen one in person, are the two terminals not marked G & W?
UK delivered RHD
Blue soft top
Blue leather
« Reply #4 on: July 30, 2023, 17:24:30 »
On mine the letters were stamped on the metal parts of terminals (those big metal bars with holes for screws).
