I recently had my soft top canvas replaced. Now I need to adjust the windows, top to fit better.
I have adjusted the windows as far as I can, so looks like I need to adjust the top to get a better fit.
Can I remove the shims without removing the springs? Do the shims have open end holes so I can slide them out, or are they closed end, whereby I need to remove both bolts and lift up on the bracket to pull the shims off?
I dont want to appear lazy but.... I cut the tip off of my pinky finger yesterday while cutting the rubber soft top window trim to fit. So..... with the injury I cant pull the spring off. Hoping I can simply slide the shims off....
Thanks!
Memphis, TN.
1997 E320
