Author Topic: headliner replacement 280SL  (Read 2557 times)
Richard Chesnick
  • USA, PA, Phoenixville
« on: August 12, 2023, 15:28:05 »
Does replacing the headliner on a 1969 Mercedes 280SL require removal of the windows?  And what type of padding is required for replacement?
lreppond
  • USA, CA, San Leandro
Re: headliner replacement 280SL
« Reply #1 on: August 12, 2023, 17:51:42 »
It’s a somewhat complicated job replacing the headliner. The side windows require removal, seals, wood trim, padding, etc.  it’s certainly doable but from what I’ve been told, tedious.  If you go this route I’d check out using sounding deadening material rather than foam. Not sure it’s possible but perhaps others can comment.
Another option is painting the liner.  Here’s a link to what Pinder did with his car.  His results are certainly impressive.
https://www.sl113.org/forums/index.php?topic=35663.0
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
dirkbalter
  • USA, CA, Corona
« Reply #2 on: August 12, 2023, 22:47:03 »
Replacing the headliner is not a quick and easy task. All the windows and most of the chrome as well as handles ….has to come of. The foam due to its age is brittle and falling apart but easy to get and replace. I believe its 8 and 5mm in thickness which you can get in multiple places. Personally, unless you are planning to restore the hardtop, I would try to save and clean what you have. If you search the forum, look for the hardtop restauration posts and guides, these will explain the liner change as well.
BTW, welcome to the group.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: August 12, 2023, 23:41:53 »
You have the procedure here: https://www.sl113.org/wiki/Tops/HardTop
Once you are there, look for rust areas to take care of them and apply rust protection overall. Also: search the forum typing "hard top" or "hard top restoration" (with parenthesis). if you search for "hard top restoration", you will also see some hits.
I am enclosing what I used as a guide doing mine.
