Katie, you may have to search a bit, using the search function. I think this has been discussed in the past.
The usual discussion has to do with solving a cooling issue, and if that's your problem, it may be useful to check out all the solutions including new or re-cored radiators, oil coolers, etc.
Dan Caron (Dr. Benz) has always suggested that a good deal of the engine's cooling is done by the oil, so an oil cooler isn't bad.
I don't have a 230SL but when I first got my 280SL back from restoration (in which the radiator was re-cored locally) it didn't like stop and go traffic nor slow driving in the heat of a sunny summer day. Some years later I had the radiator professionally re-cored through Gernold Nisius at SL Tech in Maine, USA. Not necessarily an option for you, but maybe the local folks (like Colin Ferns) can work with you.
Once I got the radiator back from Gernold my cooling woes were gone.
