Author Topic: Insulation Material Inside Long Style Fuel Pump  (Read 1116 times)
« on: August 24, 2023, 22:43:42 »
I am rebuilding long style fuel pump. The small pieces of insulation inside the motor housing, insulating connectors and wires inside, perished.
I need to fabricate them.
What is the best material I should use?
I understand they are submerged in gasoline. The original ones looked like textolite. I can get 1mm thick textolite, but I am afraid I will not be able to bend it.
Can I use 1mm thick teflon? I cannot find information that would confirm 100% that it will work in gasoline.
BobH
Re: Insulation Material Inside Long Style Fuel Pump
« Reply #1 on: August 25, 2023, 08:58:51 »
Hello Pawel, the early, long pumps are dry, no fuel in contact with the motor, so any insulating material will do the job, traditionally Paxoline was used as a base for mounting electrical components
« Last Edit: August 25, 2023, 19:27:27 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #2 on: August 25, 2023, 20:33:52 »
Ye, thank you, I mixed it up - the long one was dry.
Paxoline - it is called "preszpan" here - a cardboard laminate. I had it in mind initially, but then got sidetracked by my mistake.
Thank you again!
