Author Topic: What part is this?  (Read 2378 times)
chuen teck
  • Singapore, Central Singapore, Singapore
What part is this?
« on: August 26, 2023, 15:54:37 »
Can someone please help me identify this part?
What does this part serve?
As you can see, this part is not on contact with the linkages….seems wrong to me.
The car runs very well till after 15-20 minutes of driving, then the rpm will fluctuate between 200 & 800 and the car is stationary & will even stall at times.
Not sure if this part is the cause of the problem.
Any advice will be appreciated.
Peter h
  • Germany, Rheinland-Pfalz, Enkirch
Re: What part is this?
« Reply #1 on: August 26, 2023, 17:47:49 »
It must look like this
08.68 280sl automatic white 717 G  blue MB Tex
09.68 280sl  4-speed, now 5-speed Getrag 180 G dark green MB Tex
chuen teck
« Reply #2 on: August 26, 2023, 21:46:01 »
Thanks.
What is this part called & what’s its purpose?
Best
BobH
« Reply #3 on: August 26, 2023, 22:02:21 »
Hello, its a throttle damper or dashpot, designed to slow down the throttle return when de-accelerating to idle, i think to stop wear on the linkage, they're fitted to manual cars, so i assume your car is manual transmission?
Have a read of this and also look at the linkage tour in the tech manual for advice.  It would be worth going through the linkage adjustment as well, perhaps the arm to the dampener has come away or was disconnected by a previous owner.  There seem to have been a few types, but none of the pictures i've seen look like yours, so it may have been replaced, or perhaps there just isn't a picture of your one in the manual?
Hopefully someone more well informed will offer some advice
https://www.sl113.org/wiki/Fuel/Throttle
I've just done a general search for "throttle damper" or "dashpot" and found lots written about relacements, but still no pictures of one similar to yours
« Last Edit: August 26, 2023, 22:09:13 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
chuen teck
« Reply #4 on: August 26, 2023, 23:09:24 »
Thanks so much for the information.
Best
C T
