Author Topic: Replace Old Bulbs?  (Read 2195 times)
acbrock
  • USA, CA, Santa Monica
Replace Old Bulbs?
« on: September 12, 2023, 21:08:05 »
Hi, so I have taken the Instruments out of my car to clean and repair.   They are all looking awesome, just waiting on a repair to the speedo.  I was looking everything over and thought I would post this question to the forum.  So before tearing it all down all the light worked fine.  I can review them all now and make sure they are still ok.  But my question is should I replace them all even though they work?  I would have to bet 100% that this is the first time these instruments have been out of the car since it was built in 66.  I would hate to put it all back together and lose a bulb down the road?  or are these old bulbs better that anything I can get today?  I have read that some people have gone to LEDs since they should last a long time?
Any thoughts...
Aaron
1966 230SL Automatic 717G Papyrus White "Minny"
Re: Replace Old Bulbs?
« Reply #1 on: September 12, 2023, 22:22:25 »
Do you do enough night driving for it to matter?  Many people strictly avoid night driving for a variety of reasons.
My car hasn't run in a while, but when I drove at night I didn't mind the soft dim light of traditional bulbs.  I'll be replacing bulbs with stock bulbs when my instruments come out.
If you drive a lot at night, maybe the LEDs are for you.  That's a personal choice.
The light dimmer control works on a rheostat - an arm sweeps across a spring to vary the voltage (or something like that, I'm not an electrician).  Often corrosion builds up on that spring, so clean that if you can.
lreppond
  • USA, CA, San Leandro
« Reply #2 on: September 12, 2023, 22:41:14 »
While you have everything out and the bulbs are easily accessible, I’d change all of them. It’s what I did when I had the dash apart. I also carefully cleaned and polished all the glass and chrome on the dash and replaced all gaskets.  I did not, however, change to LED bulbs but many here have.  If you like brighter lighting, you might want to consider them.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
« Reply #3 on: September 13, 2023, 03:26:26 »
I replaced all the dash lights on my Lancia Fulvia when I restored it with small NOS bulbs since access was excellent then. Cost maybe $6 for the lot of 14 or so bulbs. I prefer not to convert to LED on classic cars.
acbrock
« Reply #4 on: September 13, 2023, 22:02:33 »
Cool thanks everyone!  I will replace them and NOT do LEDs.
Aaron
« Reply #5 on: September 13, 2023, 23:15:50 »
Don't forget to clean your dimmer.
« Reply #6 on: September 13, 2023, 23:21:20 »
The alternator or charging light should only be replaced with a standard incandescent light bulb - I'm told LED won't work. Has something to do with resistance in the system, I guess.
