Dear Friends
Just finished producing the first PAIR of READY TO GO “AIR CONDITIONING WIRING HARNESS FOR MB W113”
AS promised, they are available and special pricing will be available on my webstore (
www.Wiredoktor.com) for MB sl113.org. Just send me a message prior placing the order to send you a discount coupon.
Here below the photos of the harnesses.
They include:
1. NEW URO/Mercedes Relay for AC MAIN power, fused
2. NEW URO/Mercedes Relay for CONDENSER fan, fused
3. NEW URO/Mercedes Relay for CHANGEOVER, cuts power trigger signal to both relays while cranking
4. ORIGINAL Mercedes 100 degrees Celsius temp switch
5. Charging system boost cable from Alternator to starter (10 mm2, vs. 4 mm2 original)
6. Rubber grommet at firewall
System features:
A. Condenser fan controlled by temp switch signal and refrigerant gas pressure at dehumidifier/filter. Fan inhibited during engine cranking
B. Power to main AC console controlled by a Relay triggered by T15 ACC on signal and inhibited during engine cranking.
C. Power taken directly from starter T30 terminals. No loads taken from original car harness.
D. Compressor protected against low or high system pressure, disconnecting its activation whenever that anomaly takes place.
E. Harness will work with any MB w113 no matter it’s version : 230/250/280SL automatic or manual.
THIS HARNESS WILL WORK WITH ANY AC SYSTEM YOU CHOOSE TO INSTALL.
Regular Price will be 799$. For Sl113org members will be priced for limited time at ONLY 695$
HUrry up. Limited availability.
Best regards
Eng. Leonardo Peterssen
Www.Wiredoktor.com
