Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
hooking up tail lights
Topic: hooking up tail lights (Read 1939 times)
CJHenderson
Full Member
Silver
USA, AR, Benton
September 22, 2023, 17:36:34 »
Since there is only two connections for the taillights, one for the taillights assembly and one for the license plate, I modify the side marker to tie into the license plate plug. Question is will this work?
1950 MG-TD
lpeterssen
Vendor
Gold
USA, FL, Miami
Re: hooking up tail lights
September 22, 2023, 19:17:18 »
Dear Mr Henderson
Yes that will work but I do not like the approach you made. It is much better that you open the black connector and solder your additional wires red & black there.
Those red ring tongue terminals may touch each other if they turn and that will cause a short.
Best regards
Lp
CJHenderson
Full Member
Silver
USA, AR, Benton
Reply #2 on:
September 23, 2023, 14:48:55 »
Thanks for the concern and will make sure the terminal ends are secured from touching.
1950 MG-TD
