Author Topic: Replacing a lost Bosch Horn  (Read 3388 times)
Matt_H
  • Canada, British Columbia, North Vancouver
« on: September 25, 2023, 13:53:18 »
I have lost the 290hz horn and still have the 345 (picture attached). In searching for a replacement i have seen different serial numbers/model numbers for other 12V 290hz horns and wonder if I could replace my missing one with one of them (say from a Porsche 911)?
One I have found is a 290 Hz – Bosch number 0 320 202 023.
Does anyone know if this will even connect, mount, and work in my '69 280SL?
I am not going for a perfect resto, just wanting to esthetically match it up to the existing 345hz and replace a missing part. many thanks!!
« Last Edit: September 25, 2023, 19:39:29 by Matt_H »
BobH
Re: Replacing a lost Bosch Horn
« Reply #1 on: September 25, 2023, 19:35:04 »
Hello Matt, the Porsche horn is the correct voltage and frequency, so there's no reason it won't work on your car
Have you seen a picture of the connections and bracket on the back of the horn, do they look similar to those of the original Mecedes horns?  there are plenty of pictures on here, if you search "horn" or "horn bracket" using the search function above left
I think the brackets varied between the years and whether the car had AC or not, have a look at the pictures, they should help
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Matt_H
« Reply #2 on: September 25, 2023, 20:13:03 »
Thanks Bob. The one I was looking at has a connector like attached photo. I need to get underneath my car to see what the 280 setup for horn mounting looks like. I really just want the car to look and sound complete so kind of figuring this out as I go haha
BobH
« Reply #3 on: September 25, 2023, 20:42:07 »
No reason you can't make this fit, just need spade terminals on the wiring, yours may have had ring connectors, but i'm not sure if they changed over the years
UK delivered RHD
Blue soft top
Blue leather
« Reply #4 on: September 26, 2023, 03:06:55 »
That's why he suggested to search this site for photos, to save you the time and trouble.
m300cab
  • USA, Pennington New Jersey
« Reply #5 on: October 14, 2023, 17:55:50 »
Please see photo
Michael Parlato
m300cab
« Reply #6 on: October 14, 2023, 17:58:08 »
2nd photo
I have a video. Please send email
Michael Parlato
