Author Topic: Seat Bolt  (Read 1900 times)
jeblack123
  • USA, GA, Albany
Seat Bolt
« on: September 27, 2023, 16:13:51 »
Good afternoon,
Does anyone have a source for the bolts that secure the front of the seat rails to the frame of the car? I have tried to purchase bolts from a local nut and bolt shop, but none of them are threading easily, so I am trying to see if the original bolts are available or if anyone has any advice on a suitable replacement, I am certainly open to any suggestions.
Thanks, in advance, for your help.
James (Eddie) Black
dirkbalter
  • USA, CA, Corona
Re: Seat Bolt
« Reply #1 on: September 27, 2023, 16:25:04 »
If they don't thread easy, I would run a tap through to clean the threads prior to installation. I lost my original bolts during restauration and (temporarily) used simple socket head bolts to fasten the rails to the frame.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BobH
Re: Seat Bolt
« Reply #2 on: September 27, 2023, 16:32:39 »
Hello, the bolt sizes are in the tech manual
https://www.sl113.org/wiki/Interior/Seats
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
dirkbalter
  • USA, CA, Corona
Re: Seat Bolt
« Reply #3 on: September 27, 2023, 16:42:32 »
The normal M8 hex head with a SW of 13mm will interfere with the rails. Either use (as shown) special  SW 10mm , M8 hex bolts or socket heads.
https://boltmotorcyclehardware.com/products/m8-hex-flange-bolts
« Last Edit: September 27, 2023, 16:47:05 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
jeblack123
  • USA, GA, Albany
Re: Seat Bolt
« Reply #4 on: September 29, 2023, 10:59:29 »
Thank you both for the feedback and the link!
