Hi guys , i decided not to touch anymore the cable , it opens normally but i believe that probably is a bit loose . The feeling is that when you pull the lever , the hood doesn't pop up with the typical bounce but a bit lazier , i dont know if it's a cable problem, any advice is appreciated . The problem is that we open the hood many times with classic cars. I disconnect the battery, riconnect , check the fluids and so on . Something you never do on a modern car. For this reason i would like to know the procedure to install this safety release cable for any possible inconveniece. Thank you all
