Author Topic: What does the king pin do?  (Read 4441 times)
LFrank
« on: July 12, 2005, 13:55:51 »
I know it's for suspension, but how does it work? And how is it maintained? I ask because mine was replaced a while back but apparently needs to replaced again. (Aw $huck$.)
LFrank
Washington DC
65 230 sl - auto
DB334/Hellblau
JimVillers
  • USA, VA, Virginia Beach
Re: What does the king pin do?
« Reply #1 on: July 12, 2005, 14:46:17 »
The king pin is the part that the front wheel rotates when the wheels are turned.  In the attached image, it is large vertical item (#29).  They can "go bad" if they are not greased regularly (3,000 miles).  The king pin is normally not the item that normally wear, the upper (#80) or lower bushings (#58).
Jim Villers
Jim Villers
LFrank
« Reply #2 on: July 13, 2005, 09:51:31 »
Thanks, Jim, for enlightening me (and any others).
LFrank
Washington DC
65 230 sl - auto
DB334/Hellblau
« Reply #3 on: July 13, 2005, 11:06:22 »
<<or lower bushings (#58).
 Watch this one , in particular..
I have seen many a kingpin mis-diagnosed for this high wear item..
 Mucho Greeeeaaassss these fittings, both under load AND suspended load.
