Author Topic: Emission values  (Read 3264 times)
mauro12
  • Italy, Sicily, Messina
Emission values
« on: October 05, 2023, 17:03:50 »
Hello guys , I’ve recently overhauled my injection pump and today I did the emission test ( in Italy is mandatory a check up for every vehicles every 2 years ). The emission test have been passed but I believe the idle test in the picture shows a bit too high CO . Probably I need to re set the inj pump screw at idle and correct the mixture but the car is running great so far and I’m scared to touch anything . What do you suggest ?
Thank you
Mauro Pisani
250sl 1967 5speed zf manual
dirkbalter
  • USA, CA, Corona
Re: Emission values
« Reply #1 on: October 05, 2023, 17:48:38 »
if it ain't broke, don't fix it.
 ;D
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mauro12
Re: Emission values
« Reply #2 on: October 05, 2023, 18:21:29 »
thank you , i was only wondering how these emissions are . Im sure i need to bring the co down a bit but maybe the car is happier with more fuel. Any assessment is appreciated.
Mauro Pisani
Re: Emission values
« Reply #3 on: October 05, 2023, 18:50:07 »
Seems that getting CO low enough to pass a test is difficult.  I did a search for emission test and found a few pertinent entries among many random things.
https://www.sl113.org/forums/index.php?topic=13361
https://www.sl113.org/forums/index.php?topic=14851
https://www.sl113.org/forums/index.php?topic=30005
https://www.sl113.org/forums/index.php?topic=15631
https://www.sl113.org/forums/index.php?topic=2087
And, if you feel like reading more material, there is this: https://www.sl113.org/wiki/Electrical/EmissionControlSystem  Perhaps you'll find a problem with your system that will help you reach lower CO levels once fixed?
« Last Edit: October 05, 2023, 18:59:37 by rwmastel »
dirkbalter
  • USA, CA, Corona
Re: Emission values
« Reply #4 on: October 05, 2023, 18:59:17 »
Mauro,
take a look here.
https://www.youtube.com/watch?v=28uD3JVbQ-I
May be that helps
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Emission values
« Reply #5 on: October 05, 2023, 18:59:26 »
I have a Gunson CO tester and that allows me to tune the CO down to below 5% where (if I recall correctly) it was required to be when the car was still in the Netherlands.
Mind you, I set it only at idle, with that air/fuel mixture through the large screw at the back of the FI pump. The engine runs very well at that <5% level at idle. At normal speeds, I really don't know what the CO values are, but my car always gets through the semi-annual testing now here in France.
dirkbalter
  • USA, CA, Corona
Re: Emission values
« Reply #6 on: October 05, 2023, 19:20:59 »
I think the theoretical CO2 level published by MB for these cars is 4.56.
From what I have red, some guys feel that the cars run better with a slightly higher CO2 level.
What are the your guys at the inspection testing it to, if not to the specifications?
« Last Edit: October 05, 2023, 19:29:53 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mauro12
Re: Emission values
« Reply #7 on: October 05, 2023, 19:34:22 »
The emission test was passed anyway. The limit was 9.99. How about the HC value ?
Mauro Pisani
Re: Emission values
« Reply #8 on: October 06, 2023, 12:28:44 »
It should run fine at 4.5%. If the car won't idle smoothly at 4.5% then certainly you can richen it up to 6.5%  to try and improve things but 9% is way too high. You'll be fouling your plugs up in no time. Be careful that it's not stuck on cold start though; that will give high Co.
Your HCs are also a little higher than ideal but an "Italian tune-up" will probably resolve that.
mauro12
Re: Emission values
« Reply #9 on: October 06, 2023, 13:54:33 »
The cold start has been overhauled and is not leaking . Probably I need to set the idle screw ccw and add more air with the idle screw.
The pump has been completely overhauled and the car is running great . Plugs are not fouling . They look between black and brown , more black .
Mauro Pisani
Re: Emission values
« Reply #10 on: October 06, 2023, 17:42:32 »
This thread sheds some light on original emissions measurements.  Just double check those units of measure!
https://www.sl113.org/forums/index.php?topic=37175.0
mauro12
Re: Emission values
« Reply #11 on: October 06, 2023, 19:17:03 »
Well , you have to make some conversion in order to have the result . This is gram per mile . We are measuring at idle so I’m not so sure ..
Mauro Pisani
dirkbalter
  • USA, CA, Corona
Re: Emission values
« Reply #12 on: October 07, 2023, 16:44:16 »
Mauro,
found this for the 130 motor, the 129 should be similar.
« Last Edit: October 09, 2023, 10:00:40 by Peter van Es »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Re: Emission values
« Reply #13 on: October 09, 2023, 13:53:15 »
That extract from the technical data book is out of context.
Not all M130 engines are the same.
dirkbalter
  • USA, CA, Corona
Re: Emission values
« Reply #14 on: October 09, 2023, 14:26:13 »
That’s why I said similar. He is also talking about a 129 motor with a picture of what looks like 9.5% CO2. I think with above levels you are definitely within ball park. If you  have  better or more precise data, by all means ….
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
