Author Topic: Cold start valve nozzles  (Read 1593 times)
FresnoBob
  • USA, CA, Fresno
« on: October 07, 2023, 18:46:35 »
During hot and cold starts my newly rebuilt 250 engine starts roughly and takes a few throttle jolts to "clear her throat" and then runs smoothly.  I suspect the CSV nozzles, which spray fuel in a tulip bulb shape and far from anything like atomization.  Are new nozzles available from anywhere?  What is the typical spray pattern for these nozzles?  Am I barking up the wrong tree?
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
Lorsar
  • Membership Administrator
  • USA, NC, Charlotte
  • 1968 280SL (US)
Re: Cold start valve nozzles
« Reply #1 on: October 07, 2023, 20:51:36 »
This post should probably be in the Drive train, fuel, suspension, steering & brakes forum instead the Full member forum.
I don't believe anyone sells the nozzles but if you search the above forum, there are some threads about cleaning them.  Ultrasonic cleaning seems to yield the best results.
Lori
1968 280SL (US)
mauro12
  • Italy, Sicily, Messina
« Reply #2 on: October 07, 2023, 21:59:46 »
I’ve recently replaced the cold start valve needle , this is what you mean I guess .
Mine was leaking and not sealing properly anymore . The only website I found was the sl shop uk. I hope this helps , is quite inexpensive but the item is smaller than you can imagine . I was surprised when I received the package .
https://parts.theslshop.com/mercedes-benz-sl-w113-pagoda-cold-start-needle-valve/
Mauro Pisani
250sl 1967 5speed zf manual
« Reply #3 on: October 08, 2023, 04:19:35 »
Bob, you will need to determine if is starting rich or lean. Try a cold start with the intake solenoid dis-connected.
mauro12
« Reply #4 on: October 09, 2023, 12:33:25 »
The csv does not atomize fuel but is more a weak spray
Mauro Pisani
FresnoBob
  • USA, CA, Fresno
« Reply #5 on: October 09, 2023, 22:01:11 »
Thanks for the information from everyone.  I have ultrasonically cleaned the CSV and the needle valve seems in perfect shape.  Perhaps I'm expecting too much from a 1966 spray nozzle.  I've tried starting the car with and without power to the CSV and it starts much better with the CSV when cold, but it starts better without the CSV connected when hot.  I suspect my one-second solenoid is set longer than necessary.  I've tried to adjust this very delicate device a few times and frankly don't know the proper configuration.  Any suggestions?
Bob Comstock
