Author Topic: Right Rear Wheel Bearing 1208  (Read 1572 times)
Duncan200
  • Just started my Restoration
« on: October 12, 2023, 23:55:57 »
Hello All,
I had a quick look around the forum to see if anyone had encountered this issue and I can’t seem to see anything relating to it.
I’ve purchased an SKF 1208 EKTN9/C3 bearing as seen in an earlier post regarding these bearings.
The problem I have is that it slides straight on to the axle, no pressing of the inner race required.
I have measured the inner diameter of the old bearing vs the new and the old measures 40.00mm and the new 40.87mm.
Whilst I know that it is tightened to 200nm , I’m a little concerned about it just sliding on and not requiring any pressing.
I thought I’d put my dilemma to the knowledge of the group before I look to order another bearing somewhere else.
I guess I need to know if the new bearing would be ok, given it’s done up tight and won’t spin or do I err on the side of caution and order another bearing?
Thoughts anyone?
Thanks Doug.
1966 MB 230SL DB 717 4sp Australian Delivered Matching Numbers Car. One day it will be back on the road in all its glory.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
dirkbalter
  • USA, CA, Corona
Re: Right Rear Wheel Bearing 1208
« Reply #1 on: October 13, 2023, 00:26:47 »
40.87 versus 40.00 is way too much. Not even close. You have the wrong bearing.
Can you add the link to the post you are referring to?
One side (left) is a ball bearing, the other side (right) is a roller bearing.
Both are 40 x 80 x 18.
Looks like you have a tapered bearing.
https://www.skf.com/us/products/rolling-bearings/ball-bearings/self-aligning-ball-bearings/productid-1208%20EKTN9
« Last Edit: October 13, 2023, 01:08:33 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Duncan200
« Reply #2 on: October 17, 2023, 02:31:22 »
Hi Dirk,
This is the post I am referring to.
https://www.sl113.org/forums/index.php?topic=22226.0
You are correct it is the incorrect bearing, although it is self aligning. There is some conjecture in this post and after discussing this with my parts supplier, I am going to get the correct barrel type bearing.
I’ll chalk the money I spent on this bearing up to experience.
Thanks for your response.
Doug.
