Author Topic: "choke" adjustment 230 66.  (Read 1645 times)
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
« on: October 14, 2023, 13:43:09 »
So I know they don't have a "choke" as such, and I believe the "wax" stat operation is effectively the "choke".    My car starts and runs great when cold - IE additional revs to keep it going, and when fully hot runs fine, revs drop to 750/800 rpm.   BUT - in the middle bit, not quite fully hot, not fully cold, it has a tendency to stall as the revs are too low.
Is the adjustment in the "wax stat" area?  If so how?
Re: "choke" adjustment 230 66.
« Reply #1 on: October 14, 2023, 22:14:39 »
Find WRD Adjustment selection here.  Discussion of shims.
https://www.sl113.org/wiki/Fuel/Injection#toc-1.7
« Reply #2 on: October 16, 2023, 04:47:36 »
First, use the split linkage test to determine if it is running rich or lean during the difficult period.
