Author Topic: Body Data Plate Question  (Read 2040 times)
YEOH250SL
  • Malaysia, Sarawak, Kuching
« on: October 17, 2023, 01:51:20 »
I have recently pick up a 1967 250SL, but have trouble figuring out the transmission on the data plate. I know the definition of 10 and 12, but it states 20 on the body data plate. Does anybody know what 20 means?
Vander
  • USA, OH, Columbus
Re: Body Data Plate Question
« Reply #1 on: October 17, 2023, 02:23:29 »
2= Right hand drive
0= Manual
So it is/was a RHD manual transmission. The "1" in 10 and 12 = LHD
YEOH250SL
« Reply #2 on: October 17, 2023, 02:38:26 »
Vander,
Thanks for the info. The car has been converted into automatic. Is there a way to tell what type of manual it came as? 4 speed or 5 speed?
« Reply #3 on: October 17, 2023, 03:41:22 »
Maybe on the data card from MB Classic Center??
YEOH250SL
« Reply #4 on: October 17, 2023, 06:23:17 »
remaster, thanks for the tip. But we do not have a MB Classic center here in Malaysia. I'll try to email them to see if i5 fan be done via email.
BobH
« Reply #5 on: October 17, 2023, 09:06:26 »
Hello, line 1 on the body and paint plates show any the body-assembly related option codes, i would have thought if your car originally came with a 5 speed box, it would show code 230 on line 1
Your plate does not have any body related codes, so seems to have been supplied with a standard manual box
EDIT - Actually, after reading more about this subject, it seems the transmission code may not have been stamped on the body and paint plate, perhaps someone with an original 5 speed car could confirm
Your data card will confirm if you get hold of one
« Last Edit: October 17, 2023, 09:16:48 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #6 on: October 17, 2023, 09:08:42 »
You can obtain data card through Mercedes dealer. You need a proof of ownership.
