Author Topic: Automatic 1st gear selection  (Read 1419 times)
RAY
  • United Kingdom, England, Bromley
« on: October 20, 2023, 08:40:54 »
Would it be possible (has any body done it ) on a 69' automatic to make the car pull away in first gear all the time without having to manually select 1st ?
Mine does it randomly sometimes and having done a diff change from 4.08 to 3.46, which works great for cruising, but would quite like the extra grunt pulling away especially on gradients.
BobH
Re: Automatic 1st gear selection
« Reply #1 on: October 20, 2023, 10:56:41 »
Hello Ray, i know very little about transmission, but i found this post
https://www.sl113.org/forums/index.php?topic=4914.msg30619#msg30619
It's not exactly automatic, need to press a button wired in circuit with the kickdown switch, but saves using the kickdown, or selecting 2 and then manually changing the gear
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
RAY
« Reply #2 on: October 20, 2023, 11:57:40 »
Hi Bob,
Many thanks, I will message Tom with a few more questions.
Did you see the 1965 SL number plate auction ?
