Author Topic: 230SL Welded headers  (Read 4778 times)
cfm65@me.com
  • Cape Town, South Africa
« on: October 22, 2023, 18:19:44 »
Hi Guys,
I found one of my exhaust manifolds cracked on my 250SL and require some advice in order to fit a set of 230SL welded headers.
Could anyone please give me a heads-up on what is involved with this endeavour?
Dan, Stick and Joe?
Much appreciated.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Kevkeller
  • USA, HI, Honolulu
Re: 230SL Welded headers
« Reply #1 on: October 22, 2023, 18:42:08 »
You can’t braze the crack?
1970 280 SL
cfm65@me.com
« Reply #2 on: October 23, 2023, 17:51:45 »
Hi Kev,
No. I am going to replace the cast iron manifolds with early 230SL welded pipe headers (banana branches).
I needs advice and photos of the throttle linkage setup, as it differs from the linkages used with the later cast iron manifolds.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
DaveB
« Reply #3 on: October 23, 2023, 19:11:50 »
Those look to be in very nice condition.
There is definitely a different linkage setup to suit these headers. Most likely the parts are NLA new and hard to find used. But probably relatively simple for a machine shop to duplicate if you can borrow a set or get a good diagram. Sorry I cannot help with part numbers or a diagram as I am not at home.
DaveB
'65 US 230sl 4-speed, DB190
DaveB
« Reply #4 on: October 23, 2023, 19:20:28 »
And, as you will be aware, they also require a specific matching front section of the exhaust, which may be hard to get currently.
DaveB
« Reply #5 on: October 23, 2023, 20:37:13 »
It took quite a lot of searching.
https://www.sl113.org/forums/index.php?topic=24128
If you owned a few MB parts books, you would have been able to look up the part numbers.  That may be an investment worth considering.  Still, you're going to have to search hard for this stuff on the used market or find someone to replicate it.
DaveB
« Reply #6 on: October 24, 2023, 03:46:04 »
Good searching Rodd.
DaveB
« Reply #7 on: October 24, 2023, 14:26:24 »
Chris, you might explore going to a custom exhaust shop and have them manufacture a set that will fit your current exhaust and won't require modification of your throttle linkage. Might be easier, cheaper, quicker and even better than sourcing a 230SL set?
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« Reply #8 on: October 24, 2023, 16:00:48 »
My 230 came welded headers. I did not see  any modifications to the linkage because of this type of headers. I think the issue you will have to deal with is the length of the down tubes are different than cast iron exhaust manifold.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
« Reply #9 on: October 24, 2023, 16:47:13 »
Alex,
See my link posted above.
cfm65@me.com
« Reply #10 on: October 24, 2023, 17:23:10 »
Hi Guys,
Thanks for the input.
After plating today, the headers looking much better.
These front pipes are still available as a unit and/or two loose pieces.
Any further advice or photos will be much appreciated.
Regards
Chris
If anyone is interested I will place photos as I progress.
« Last Edit: October 28, 2023, 12:24:18 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #11 on: October 24, 2023, 18:59:02 »
Very interested in how you resolve the linkage changes.
cfm65@me.com
« Reply #12 on: October 24, 2023, 19:28:23 »
Rodd,
I assume your 230SL have the later cast iron manifold like my 250SL?
I managed to get a few different linkage parts from a wrecked W108 with a M130 engine. Plated and seen clearly in one of the photos above.
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #13 on: October 24, 2023, 20:23:46 »
Sorry, I did not enlarge that photo and didn't notice the small parts.  Let us know if they work out for you, since they're from a M130 instead of an early M127.  Wishing you the best!
« Reply #14 on: October 25, 2023, 08:35:43 »
Here’s some photos of the linkage of a RHD 230
« Reply #15 on: October 25, 2023, 13:26:52 »
Chris,
Is your car RHD?
cfm65@me.com
« Reply #16 on: October 25, 2023, 15:34:19 »
Thanks Colin,
Looks very similar to the bits I got off the 108 engine.
Much appreciated.
No Rodd, I have a lefty, but every little bit of help, photos and advice would be great.
Regards
Chris
« Last Edit: October 28, 2023, 12:26:54 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #17 on: October 26, 2023, 14:50:29 »
I don't think these parts are different for RHD or LHD.
BTW, plating an exhaust manifold is a total waste of time and money unless you're building an engine to put in a glass case for display.
cfm65@me.com
« Reply #18 on: October 26, 2023, 19:29:00 »
I agree, Colin,
However the headers looked terribly tatty and I realise the yellow passivate won’t last and the electroplating will probably turn blueish.
But, for now its looking good  and who knows, I might never get it sorted and running properly and that is really all that counts.
Please hold thumbs.
Thanks again for the photo above. I think I might be winning slowly but surely. I have swapped some of the balls on the pivots over to the other side of the brackets and pivots, in order get the setup to work and moved it slightly further away from the engine block.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
DaveB
« Reply #19 on: October 27, 2023, 06:53:16 »
Hmm, yes that’s what I thought but wasn’t going to say 😀
They were in way better condition than most.
DaveB
cfm65@me.com
« Reply #20 on: October 28, 2023, 12:12:43 »
Hi Guys,
I think Ive managed to get it all together. I’ll have the exhaust modified and fitted before start up.
Second photo, throttle closed.
Regards
Chris
« Last Edit: October 28, 2023, 12:20:48 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #21 on: October 28, 2023, 14:10:57 »
I think some have had their manifolds "ceramic coated". That's a thing, yes? Certified for high temperatures, and prevents them from getting tatty?
« Reply #22 on: October 28, 2023, 16:09:55 »
Hi Guys,
Regards
Chris
Something about that geometry doesn't look right Chris.
cfm65@me.com
« Reply #23 on: October 28, 2023, 20:02:57 »
Thanks Colin,
Do you mean the angle of the vertical rod or the angle of the upper L shaped leaver?
As you know, both these angles are adjustable and I have not paid much attention or checked the pedal position vs butterfly angle, yet.
HOWEVER YOUR INPUTS ARE MUCH APPRECIATED.
I need to fit the exhaust first. Our local exhaust shop is only a kilometre or so away, but past the traffic cops as well as the local roadworthy centre. Without an exhaust! 😳
By the way.
We are watching the world cup rugby match. PLEASE hold thumbs. South Africa might be the WORLD CHAMPS for the forth time.
Thanks again, Colin.
Regards
Chris
« Last Edit: October 28, 2023, 20:09:44 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
cfm65@me.com
« Reply #24 on: October 28, 2023, 21:07:28 »
Thanks Guys,
South Africa won the world rugby championship for the 4 time. First team ever to win 4 times.
Regards
Chris
Cape Town
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
