Author Topic: Indicator Cancellation Stalk/Steering rack  (Read 2223 times)
230SL
  • United Kingdom, England, Cookham
« on: October 26, 2023, 11:51:11 »
Hi there
I apologise for yet another post about non cancelling indicators, and I have trawled through all the great advice on this site!
My car is a 1964 230Sl and I have the dreaded non cancelling indicators. I have checked the orientation of the steering shaft and sadly, that is correct. I am in the throws of removing the stalk, and I'm pinning my hopes that I can fix it as per Allenh's Excellent fix from 2009, with heat shrink. What I can't find is a good pic of the cancel pin on the steering shaft? There is a pic on the Wiki, but I can't tell if its a round pin and how far it sticks out?
If its not that, its some open heart surgery on the stalk unit, which is something I am loathe to do, as I'm terrified of ending up with a handful of springs and levers, and no wipers as well as indicators!
I have also read Greg and Georges most excellent Turn Mech repair, and although I understand what's required, not sure I'm up to it!
Thanks in Advance
Rob
BobH
Re: Indicator Cancellation Stalk/Steering rack
« Reply #1 on: October 26, 2023, 12:55:50 »
Hello, did you see this post?, some more good pictures and a PDF attachment on post #8
https://www.sl113.org/forums/index.php?topic=36165.msg264826
And this post
https://www.sl113.org/forums/index.php?topic=30504.msg242586#msg242586
« Last Edit: October 26, 2023, 18:57:06 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
230SL
« Reply #2 on: October 26, 2023, 19:19:18 »
Hi Bob
No, I didn't!
Many thanks!
Rob
230SL
« Reply #3 on: October 27, 2023, 12:15:06 »
Hi there
I have finally plucked up the courage to attack this, and have released the stalk as per the Tech diagram 54-17/1 shown. What I am struggling with, is getting enough slack on the cables to be able to get to the terminals on the stalk, as shown. is there a way of releasing the loom, or do I just use a bit of brute force!
many thanks in advance
Rob
230SL
« Reply #4 on: October 27, 2023, 13:28:58 »
Update
I removed the trim under dash and that enabled me to push loom through. Fingers crossed the heat shrink trick works!
Rob
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #5 on: October 27, 2023, 14:22:36 »
Update
Rob
I offer professional repair of those switches.
https://www.sl113.org/forums/index.php?topic=36677.0
1964 230SL
230SL
« Reply #6 on: October 27, 2023, 14:37:20 »
Thanks Sead
If this fails, I may be in touch!
BobH
« Reply #7 on: October 27, 2023, 15:24:40 »
My indicators never used to cancel, i think one side was worse than the other. Then one day they decided they would no longer lock in position, so i had to hold the stalk in place , tricky on roundabouts.  I was going to send them to Sead over winter, as i didn't want to tackle the job myself
Then, a few weeks ago, i was out and had to use the wipers, hence i pushed the stalk in, and hey presto  the indicators started working again.  No doubt they may fail again if something is worn or loose
UK delivered RHD
Blue soft top
Blue leather
