Author Topic: 250 TALL PUMP  (Read 1516 times)
harrycovert
  • France, Midi-Pyrénées, castanet
250 TALL PUMP
« on: October 27, 2023, 07:01:12 »
I have a small fuel leak from the vent pipe on my original tall pump
I have looked at the exploded diagram of the pump in the technical manual
Would it be No 34 the sliding packing ring that is causing the problem?
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
Re: 250 TALL PUMP
« Reply #1 on: October 27, 2023, 09:11:27 »
yes. there is reproduction available now.
https://vintageeuroparts.com/product/bosch-long-style-fuel-pump-bellow-only-w108-w111-w113-0010913401-0442200007/
1964 230SL
MartinK
  • Germany, Hesse, Büdingen
Re: 250 TALL PUMP
« Reply #2 on: October 27, 2023, 09:14:13 »
Thanks, Sead. This Item I searched, too but did not find. I replaced the rotating packing into a standard shaft seal ring. The Problem is, if the sealing counterpart in the pump housing is bad, the pump will be leaking anyway. This part only helps you if this is the problem. A rotating packing seal contains always two parts. The static one in the housing and the rotating one on the shaft. Talk soon, Martin
