Dear Friends:
JUST LAUNCHED another wiring harness product that I personally consider a MUST for everyone driving a w113-230/250SL.
As you may know early MB Pagodas used a different COLD START logic than the one implemented by Mercedes in later cars with mechanical fuel injection.
They key problem on that early design was the use of two components which are NLA, and therefore market good used units asking price is ELEVATED.
I am talking about:
1. TIMED RELAY.
The “old can style” one second timed relay is NLA and this unit after 60 years of operation, shows in most of the cases an non consistent operation; which translates into random difficult engine starts. Prices for this component are above 500$
2. TTS With screw terminals.
Thermo Time switch is a vital component on your MB w113 cold start logic. This component based on the bimetallic heating principle, fatigues with time and produces therefore, erratic signals which convert into difficult engine start up. NEW units, can be sourced for rocket high prices as 900$. Same kind of TTS Units like the one used on Porsches or later Mercedes as W116 /126 which have solid state electronics instead are readily available through many vendors. As offer is broader prices for new units can be as low as 85$.
This harness which I present here will allow MB w113 230/250SL owners to run their cars on the latest COLD START LOGIC which will bring to your loved Sunday drive the reliability you dream.
This is a PLUG AND PLAY solution that will allow you to use original Mercedes Benz electric components available everywhere at a much lower price point, saving you hundreds of dollars among giving you the confidence that your car will start up without hesitation every time.
Harness priced very competitive at only USD 695, which is a bargain considering the savings you will have because you will not be forced to buy specific old electric components like the 1sec relay, and old style TTS (500+900=1,400$ in savings).
Enjoy this innovative solution and spread the word among colleagues.
Also available for free an adapter if you still want to use screw type TTS.
Best regards
Eng. Leonardo Peterssen
Www.Wiredoktor.com
