Author Topic: ZF Transmission Manual  (Read 1011 times)
gcdnevadacity
  • USA, CA, Nevada City
« on: November 17, 2023, 03:55:39 »
Hello, I'm looking for help locating a service manual for a 1964-1966 ZF 5 Speed transmission. My shift linkage needs help - perhaps bushings. Any suggestions are appreciated. I think my unit is ZF S5-20 but not certain. Unfortunately the data plate is missing. However the outer case is 1025 401. I hope that helps some.
Thank you.
DaveB
Re: ZF Transmission Manual
« Reply #1 on: November 17, 2023, 05:14:14 »
I believe all shifter and linkage bushings are the same as the standard 4-speed. Maybe others can confirm. I have the ZF manual but it doesn’t include the linkages. If a search of the site doesn’t turn up the pictures and part numbers I can look them up.
DaveB
'65 US 230sl 4-speed, DB190
« Reply #2 on: November 17, 2023, 07:02:05 »
Indeed, the only parts I see on the parts list (EPC) that are different for ZF are:
- rear support A 113 242 01 01
- pull rods A 113 260 10 89
- shifting tube A 113 260 06 82
- knob A 111 268 05 42 (this one is available)
The rest, as it looks like, is the same.
SA code for ZF is 10603 in case you need it.
DaveB
« Reply #3 on: November 19, 2023, 12:17:44 »
Here is the picture cross-referenced to the part numbers.
It's probably easiest to call the Classic Center parts division and tell them you'd like all shifter and linkage bushings.
DaveB
DaveB
« Reply #4 on: November 19, 2023, 12:19:00 »
next pages..
DaveB
